Ubuntu 12.04 on x86_64, Nvidia GeForce GTK 680
2.67b
With certain meshes the preview of the skin modifier causes blender to segfault when ctrl+a scaling certain vertices to zero. This happens when I want to individualy scale a vertex to a precise value between zero and one.
- start with the default scene
- remove the faces from the default cube
- add a skin modifier
- select the top 4 vertices
- press ctrl+a and write '0' or '.'
Comment Actions
This is causing an assert in bullet:
blender.bin: extern/bullet2/src/LinearMath/btConvexHullComputer.cpp:1706: void btConvexHullInternal::merge(btConvexHullInternal::IntermediateHull&, btConvexHullInternal::IntermediateHull&): Assertion `dot <= 0' failed.
Comment Actions
Same bug as T38521: blender crashes when scaling all vertex radii to zero when skin modifier present which was fixed some time ago, I forgot to close this report as well.
