Calling a pure python script like the Ogre mesh exporter "ogreexport.py"
(attached), cab crashes blender.
I have made a simple .blend file to reproduce it (cyl.blend attached).
1- load cyl.blend
2- call the Ogre XML export script.
3- just click 'Export' in the GUI
4- in the case you reach, it means that this is one of the lucky cases
where it did not crash. Repeat step 3 for a crash.
The last things blender outputs is:
Using Python version 2.4
*** glibc detected *** free(): invalid next size (fast): 0x0000000001498a90 ***
Aborted
Logged In: YES
user_id=4200
Apparently there is really something going on with the Python interface.
I have been trying to update the code for the Ogre Exporter (since it seems
to use methods no longer in the Python interface), and get more hints
that there is memory corruption.
I get sometimes this:
*** glibc detected *** corrupted double-linked list: 0x00000000012a8460 ***
Aborted
I do not know whether this is useful or not, but this all with blender compiled
from source on Linux with:
kernel: 2.6.12-10-amd64-k8
python: 2.4.2
glibc : 2.3.5
gcc : 4.0.2 (I tried with 3.4, but same crashes)
