Tested on Windows XP, 2.40 RC1, Radeon 9600. Also tried with 2.37a which failed to reproduce the error.
1. Use the included .blend file (a plain grid, the rightmost viewport is for showing the vertex that actually gets selected)
2. Go to edit mode (without moving the viewport) and try to select a vertex in the left viewport by right-clicking.
--> The result: the vertex outside the view gets selected.
3. Pan the view a bit so the whole grid shows.
--> Vertex selection works correctly.
4. Zoom in so that no border vertices are shown, try selecting vertices.
--> Vertex selection alternates between certain border vertices.
5. Pan the view so that the vertex in the upper right corner shows.
--> Vertex selection works correctly again.
Comment Actions
Logged In: YES
user_id=3336
Works correctly on my Geforce, so it's probably a Radeon issue.
Comment Actions
Logged In: YES
user_id=103
I have same ATI type, but in OSX, which works fine. Drivers are always tricky... you might check for newer ones, or for a downgrade even!
Comment Actions
Logged In: YES
user_id=3336
Works fine for me in 2.40 final, so this one can probably be closed.
Comment Actions
