--- Operating System ---
Windows 7 64bit
--- Blender version with error ---
Blender 2.67-2.67b 64bit (official build).
Derived mesh explodes to infinity while using solidify modifier with tubular non-manifold base mesh if "Even Thickness" AND "High Quality Normals" are checked (but not both). This is probably related to the geometry of the base mesh. However I could not find any similar cases where non-manifold mesh would explode.
See attached file for this particular geometry.
1. Open attached file
2. Go to solidify modifier ("Circle" object).
3. Notice that "Even Thickness" is set and mesh looks as expected
3. Check "High Quality Normals" option -> mesh explodes
4. Uncheck "Even Thickness" -> mesh looks good
5. Check "Even Thickness" again -> mesh explodes
Kristijonas
