Shadow pass problem
Hello
i want simple shadow pass with environment lights on .....
but when i turn on environment lights and "only shadow" on ground plane then i just not get proper shadow
here is a little example of what i want and what it comes
i could have submit this long ago ..... sorry for the delay ...
and if i am doing something wrong then let me know .... but as far as i know ... one should get proper shadow pass only with one click ....
in the blend file , i have on env lights and "only shadow" on ground plane
when u hit render u can see shadow is only on the radius of AO
turn off the "only shadow " on ground plane and check render ... now you should get proper long shadow .... this is how it has to b while we turn on "only shadow " with env lights
and even when u off env lights . ull get proper shadow
we guys are struggling in 2.63 if possible make some script to make it possible in 2.6X and 2.63 too
thanks
Closing, duplicate report.
Thomas Dinges (dingto) changed the task status from Unknown Status to Archived.Jun 12 2013, 10:00 PM
