Hello
i want simple shadow pass with environment lights on .....
but when i turn on environment lights and "only shadow" on ground plane then i just not get proper shadow
attached image is an example of what i want and what it comes
i could have submit this long ago ..... sorry for the delay ...
and if i am doing something wrong then let me know .... but as far as i know ... one should get proper shadow pass only with one click ....
in the blend file , i have on env lights and "only shadow" on ground plane
when u hit render u can see shadow is only on the radius of AO
turn off the "only shadow " on ground plane and check render ... now you should get proper long shadow .... this is how it has to b while we turn on "only shadow " with env lights
and even when u off env lights . ull get proper shadow
we guys are struggling in 2.63 if possible make some script to make it possible in 2.6X and 2.63 too
thanks
