Blender Render Border render settings (T-Panel) Camera Only instant crash
Arch linux 64bit Ati 5770
Rev 57368 broken Rev s7440 still broken
Crash when toggling Camera Only in Set Render Border (T-Panel) Blender Render
Load Factory Settings , set Render Border Ctrl+B doesn't matter if you are in camera view or outside, set viewport to rendered,
now check Camera Only in the T-Panel under Set Render Border settings, it will either crash or switch you to Cycles Render.
Developer note:
This is because redo frees the main. Ton has this in his list of to-be-fixed things already. Assigning to him.
Fix in svn revision 58082, thanks for the report.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jul 9 2013, 12:26 AM
