Windows 7, NVidia GeForce G210
2.67b
Only few vertices moves in animating a mesh with a rigged mesh deform modifier.
Comment Actions
The normals of the cage mesh are pointing inside instead of outside, they need to point in the right direction to determined the inside/outside.
I've added a note about this to the documentation now.
http://wiki.blender.org/index.php/Doc:2.6/Manual/Modifiers/Deform/Mesh_Deform
Comment Actions
Thank you! Other guys from blenderartist have come to the same issue (http://blenderartists.org/forum/showthread.php?298128-Mesh-Deform-Modifier-not-working) and I didn't see the last comment which solved the problem.
