Show weights not working with a weight edit modifier in edit mode
Ubuntu 64, 16gb ram, 2* nvidia gtx560tioc
current trunk does not work (just compiled myself a clean one and tried a buildbot build)
I'd like to show the vertex weights while in edit mode and have a modifier on my plane that alters the vertex weight. When I set up the modifier to show up in edit mode too, the mesh hides all its weights and looks like as I've never ticked the "show weights" checkbox.
Open the blend, go into the edit mode (if not already in it) and click on the modifiers "Use modifier while in edit mode" -> The weights will disappear.
Greetings, Thomas
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Jul 1 2013, 2:42 AM
Hi Campbell,
just came back from holidays and saw your fix... great! Thank you very much!
Sorry,
but I tested again, and altough I see the weights in the edit mode now, I don't see the weight-change! Just open up the supplied blend and have a look (alt+A) in Weight paint mode vs edit mode..
Greetings!
Fixed r58009. both cases work now :)
