error found in 2.670 r57123
bmesh.ops.contextual_create doesn't work properly
add a primitive plane, select it, go into edit mode
use the console type this in or execute this from the text editor:
import bmesh,bpy
mesh=bpy.context.active_object.data
bm=bmesh.from_edit_mesh(mesh)
bm.verts.new((1,1,1))
bm.verts.new((-1,1,1))
bm.verts.new((1,-1,1))
bm.verts.new((-1,-1,1))
bmesh.update_edit_mesh(mesh)
bmesh.ops.contextual_create(bm,[bm.verts[4],bm.verts[5],bm.verts[6],bm.verts[7]])
creates the error
TypeError: bmesh operators expect a single BMesh positional argument, all other args must be keywords
which doesn't make sense considering the 2nd argument has to be a list of bmesh objects to operate on, at least according to the API
http://www.blender.org/documentation/blender_python_api_2_67_1/bmesh.ops.html?highlight=bmesh.ops.contextual#bmesh.ops.contextual_create
I hope I made no mistakes and this is actually a bug...
Thanks!
Comment Actions
hell Max,
as i understood the message you have give the second and all following arguments its keywords except of the first one - this you have to give without its keywort in the parameter list...
like:
bm,
geom=[bm.verts[4],bm.verts[5],bm.verts[6],bm.verts[7]],
mat_nr=1,
use_smooth=False
