Tested with r57892
Never?
If you mark edges sharp via operator, they show as cyan lines in viewport. If you use the use_edge_sharp / bm smooth properties, they don't, previously marked edges even lose their cyan color although the state didn't necessarily change (see attached .blend)
Run the script of attached file
Comment Actions
This isnt a bug, the tool enables the mesh draw option, the python attribute doesn't, they just work a bit differently.
You can enable the draw option with:
bpy.context.object.data.show_edge_sharp = True
Comment Actions
the draw option is enabled in the file i attached, but i didn't realize that i cleared the sharp-state (smooth=True), i meant to write smooth=False to make all edges sharp - my bad! It works fine with bmesh module, standard API requires mesh to be in object mode - like for selection.
