"rendered" viewport does not update
Windows 7 64bit, intel internal HD4000
latest tested with issue:
blender-2.67-r57951-win64.zip
the blender internal "rendered" 3D viewport sometimes does not update.
(i really like these "rendered" viewports)
- open the attached blend file
- on the left viewport change to "rendered".
- select an object in that viewport and make some (faster) grab movements with the object (e.g. [G]+[Shift][Z]).
sometimes when you click the mouse, to accept the grab/scale/.. changes, the rendered viewport stays in an older unupdated version of the scene.
specially when your viewport is zoomed in it happens on my system.
watch the attached video, to see, what i mean.
(it is not a big problem, if the viewport does not update during the change process - i think for that it is not made for, but it should be up tp date for sure, then the change is done in the scene.)
I have the same issue.
Windows 7 Professional 64 bit
Intel Core i5 CPU M520 @ 2.4GHz
8.0 GB DIMM
ATI Mobility Radeon HD 545v
blender-2.68-RC1-windows64.zip (2.76.1 r57908)
Wasn't available in previous release
viewport render for cycles is fine.
viewport render for Blender Internal: does not update quickly, takes 5+ seconds to rebuild viewport image for every mouse move.
Have attached BI-lagging.blend as the file I was using to show.
same under Linux (ubuntu 13.x) / blender-2.67-r58014-linux-glibc211-x86_64
Fix in svn revision 58082, thanks for the report.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jul 9 2013, 12:26 AM
