Windows 7, Nvidia gtx 460 se
Blender 2.68
Bevel modifier not work with Limit Method: Weight or Vertex Group
Add cube, add bevel modifier, then try to use Limit method like Weight or Vertex Group
Thx
is very important this limit method for me because i need to use multiple bevels modifiers with difference value
thx
I checked your scene and all methods work fine as they should except that currently the state is as follows (as far as I know):
Bevel weights are intended to work with edges and thus only have an effect, when "Only Vertices" is inactive.
The other way round, vertex maps are only used when "Only Vertices" is active.
Some more information can be found in Bug Tracker #34614 found here:
http://projects.blender.org/tracker/?func=detail&atid=498&aid=34614&group_id=9
It's a duplicate of the other bug, so I'll close this one, and you can follow progress there.
