OS X 10.8.4 AMD 5770
58141
If you enable Full Sample AA and try to render with an external engine (ex, Yafa, Lux), Blender will lock up or crash when attempting to load the render result. Turning off FSAA fixes the issue. Cycles seems unaffected, and also lacks a checkbox for full sample. It seems it has some ability to ignore it? If so, this should be the default handling for all external engines.
-Make a scene (any scene, default cube is fine), turn on AA and full sample
-Render with BI and Cycles, all is fine
-Render with an external engine such as Yafaray or Lux, Blender will lock up or crash
-Turn off full sample and the external engines work fine
Comment Actions
Developer note: Wondering what's wrong here.
validate_render_settings() should catch this case via RE_engine_is_external()?
Comment Actions
Fix in svn revision 58174, thanks for the report.
The problem is the save buffers option (automatically enabled by full sample). It requires specific tile sizes and if they don't match what OpenEXR expects file saving can get stuck, but when you're already loading the result from an EXR file it's also not very useful to have anyway.
Now I've made support for his optional, with a bl_use_save_buffers property for RenderEngine, set to False by default.
