All objects disappearing from BI render after first frame.
OS X 10.7.5, NVIDIA GeForce GT 330M 512 MB
Tested with official 2.67a, 2.67b and nightly build 58190
Rendering single frame when in 3D view, 1st render is correct, but when re-rendering while still showing render result, no objects appear in render.
Rendering animation from menu: all objects disappear from render in all frames.
1. Open .blend
2. Hit F12 to render single frame
3. Hit F12 again to render frame without objects
4. repeat...
OR for animation
1. Open .blend
2. from menu select Render > Render Animation
3. render frames have no objects
BUT (I just discovered)
1. Open .blend
2. Hit Ctrl-F12
3. animation renders OK, UNLESS a frame is already rendered and result showing rather than 3D view.
The problem here is that you have 3D view layers decoupled from scene layers (button next to the layers in 3D view header). There's a feature when you press F12 with the mouse over a 3D viewport, it will then render with the layer and camera from the 3D viewport rather than the scene. When rendering again with the mouse over some other editor it will use the scene settings again, which is why the objects disappear.
It's a confusing feature, perhaps it could be communicated better.
I've added some text the to the render info at the top of image editor now. Maybe still not ideal but there isn't really a bug here, just not so great UI design.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jul 12 2013, 6:34 PM
Appreciate it Brecht. A feature I didn't understand obviously, sorry for that.
