bug with boolean
Window 32 bits
Video : G31/G33
2.68 official SVN from blender org
i did a boolean between a sphere and a (cylinder + sphere)
and i get an infinite line which i cannot get rid of !
see file
just open file and look at the line !
thanks
It looks like you have included only the result of the boolean.
Could you include the objects before they are operated on?
here is a new file with original objects
now i'v redone at est in a new file
and could not reproduce it !
not certain why this original file where i ahd problem is doing it
thanks
sorry was unable to upload new file here !
not certain why or how to do it !
so here is a new file with bug in last post
i remove most of the other objects from the original file and kept only the objects with problems
hope it does not matter !
filename = bug2
http://blenderartists.org/forum/showthread.php?299822-bolts-sculpted-prot-to-cycles&p=2419245#post2419245
as i said i tried to redo it in a new file ans was unable to redo the bug !
thanks
in 2.68 official version from blender org
Win 32 bits
video G31 / G33
new boolean problem
see file bugbool5
in first post in this thread
i guess this is a new bug with boolean
cause normaly it does not do that ?
now here i added a sphere and a cylinder
then added the boolean union on the sphere and use cylinder for the other object
as you can see in file if you move the sphere up and down i will disappears!
now sorry still not able to reproduce at will
have to find how/when to reproduce each time!
i will continue to experiment and try to find how/ to reproduce it !
thanks
Your cylinder is opened! Results of boolean operations cannot be guaranteed with non-manifold and/or opened meshes... Just close your cylinder and everything works as expected.
i read wiki and if i remember well
it says that we can use open objects with boolean
are you saying this cannot work on open objects at all?
and in case it does would it be possible to limit the values of verts to a certain max value?
iotherwuse the mesh data is totaly screwed up and cannot be use anymore
in other words you get a scrap file and that is not fun ?
thanks
