Particle system (hair) goes wrong after removing an influence texture
imac OS X (10.8.4)
4 Go ram
ATI Radeon HD 2600
Error happened on 2.68.0 official release, 2.68.1 (r58566) and earlier
Influence texture still influence a hair particle system after you unlink it from the Particle > Textures Panel
_Open start-up file
_Enable Cycles render engine
_Add a basic hair particle system on the default cube
_Go to the textures panel available in the particles properties and add a texture in the first slot
_Use the "show texture in texture tab"
_Default "clouds" texture is fine, just check the "Density" influence
_Back in the particles properties remove the influence texture by using the unlink button
_There's no more hair visible, density still influenced by an empty texture
(You can have your hair back only if you go in texture tab and uncheck Density for the ParticleSystem)
Fix in svn revision 59026, thanks for the report. On existing files with such a setup you will have to force a particle refresh to fix the issue, like tabbing in and out of edit mode.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Aug 8 2013, 8:12 PM
