Mirror modifier does not mirror vertex normals when there are no faces.
Gentoo Linux x86_64
Kernel version 3.9.8
NVIDIA GeForce GTX 560
blender.org build version 2.68a
When there are no faces in a mesh (as when working with the skin modifier) and the mesh has a mirror modifier, vertex normals on the mirrored copies of vertices point in the same direction as their source verticies, rather than being mirrored.
From a factory default file:
1. Enter edit mode for the default cube.
2. Turn on display vertex normals under Mesh Display.
3. Select all vertices delete them.
4. Add a mirror modifier.
5.Turn on "Apply modifier to editing cage..."
6. Create a single vertex.
The normals for the new vertex and its mirrored copy will be pointing in the same direction, rather than opposite. This will continue to affect other vertices until a face is created. Recalculating normals does not correct this, but applying the modifier will result in correctly mirrored normals.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Aug 27 2013, 4:25 AM
