VSE skipping frames
OSX 10.6.8
Blender 2.67b
When rendering a sequence in the VSE, Blender will skip frames but maintain the same frame rate. This results in a video that runs twice as fast. The preview while editing is running at the appropriate speed. This doesn't always happen. If I only have one video clip in the timeline, it works fine. If I add a second clip, it will start cutting out frames.
Could you please attach .blend file which demonstrates the issue, this always saves ton of time needed to reproduce the circumstances?
One week without reaction… We can always reopen if you provide required data. :)
Further more, it could very well be that you are using AV-Sync or FrameDropping sync modes, in which case this behavior is perfectly normal!
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Aug 25 2013, 8:04 PM
