Linux Mint 15, Geforce GTX 580
Blender 2.68 rev 58463, from IRIE shinsuke (deb package)
The rotation animation plays correctly in the viewport, but if you either render the animation or switch
the viewport to rendered or textured, propeller blade rotational position is messed up, even then when you switch
back to solid, CTRL Z resets this to correct state again, but i am unable to render out the rotating propeller (its an object group instance)
Open Blend and animate in viewport. The propeller should rotate correctly. Then if you try to render in any way (Blender internal tested only)
Propeller Blade position is messed up.
Comment Actions
ok, thanks to a tip i got this bug can be considered as closed, i forgot to add the empty to the group being instanced. but strangely this looked like to work too in viewport.
Sorry for the inconvenience.
scorpion81
