Boolean modifier is broken (58825)
Arch Linux 32bit, Radeon HD4200
Blender revision: 58825
It's just me or boolean modifier is broken?
When hit apply nothing happend.
Steps to reproduce the error:
Create a cube and a sphere with same location and use boolean modifier on one of them.
I cannot confirm this, please add detailed steps to reproduce the issue (i.e. which object you add the modifier to, and what bool op you use).
HI!
Sorry for bad description.
I should've said to make sure 2 objects is intersects, obvioulsy when in same location they don't intersecting.
So you need to move sphere up a litle bit.
Anyway I just can't make boolean modifier work no matter what bool op I use.
Can’t reproduce that… What build do you use ? If not one from http://builder.blender.org/download/ (“official” trunk builds), please try one of those first of all!
I built blender myself (the lattest trunk's revision).
Hmm.. maybe this is the problem, maybe I don't included some library.
Ok, thanks. I'll try.
I tried an “official” trunk build and it's works.
It seems the problem in some way in my build's environment.
Ahh, I very sorry for false report.
No problem, just be sure to always test a buildbot build before doing a bug report, these use exactly the same environment as releases!
Anyway, closing. :)
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Aug 2 2013, 4:08 PM
