No Alpha when using RGBA output
Windows 7 , Nvidia 580 + Nvidia Titan
2.68 , Worked in 2.62 at least maybe even in more recent ones.
When rendering in blender internal you could select RGBA for output.
This would give you a image of just your object , on a alpha channel, No background.
In version 2.68 the gray background seems to persist no matter what you do.
I tried the same thing on a other system with a old version 2.62 to check if it was not my mistake, but it worked there.
It seems that by adding the blender internal viewport render ( which is nice by the way ) some other things got broken.
Select RGBA for output, and check if the grey background is replaced by a alpha channel.
Go to the render panel and look under shading and change the alpha setting from sky to transparent.
Still get the problem?
:-o that does work!
Strange, that did not seem to matter in previous versions.
Did the default for that change?
Alpha Transparency Handling was changed in Blender 2.66
http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.66/Image_Transparency
>> Closing
Thomas Dinges (dingto) changed the task status from Unknown Status to Resolved.Aug 4 2013, 2:05 PM
