Bevel modifier with smooth shading - bug
Windows 7 Pro, GeForce 550GTX
2.68.0 r58368 official build
I'm trying to do a nice highly detailed building block. I want to use bevel modifier (with edge weights) because it's non destructive and gives me more freedom than doing "hard coded" subsurf with edge-loops everywhere. When I'm applying smooth shading on with more bevel step than 1 there's issue with visible edges between faces that should be smooth - everything is on the attached screenshot.
.blend file attached
Ok, after some additional tests it look like that only non glossy shading is affected - see second screenshot
Howard: could you check this report? Thanks!
Thanks, I will look into this after I fix some other bugs in my queue (working some knife ones right now).
I looked at this and am not convinced that the bevel modifier is implicated here at all. I removed all modifiers and still could not get the faces to smooth shade with cycles. I think I will assign this to brecht to see if he can see what is going on. If it is the fault of Bevel, I guess it would be because bevel didn't properly propagate some flag or property to newly created edges, faces, or vertices. If someone could tell me what the property is, feel free to reassign this bug back to me.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Feb 6 2014, 7:22 PM
This appears to be another instance of the dreaded shadow terminator problem:
http://archive.blender.org/development/release-logs/blender-234/misc-improvements/
http://www.geekshavefeelings.com/x/wp-content/uploads/2010/03/Its-Really-Not-a-Rendering-Bug-You-see....pdf
I'd like to find a better solution for this but it's not considered a bug at the moment. Basically what happens is that while the shading can make the geometry looks smooth, the true shape of the geometry can be revealed by the shadows. The only solution in Cycles now is to use more subdivision or tweak the light size and location to avoid it.
