OpenGL Render: Rendering objects with wireframe are not visible if the viewport is hidden
Windows 7 x64, gtx 580
fail with r59044
fail with r46883
If the Viewport is hidden and you do a opengl render, wireframe objects are not rendered
1. open attached file
2. go to the render menu -> OpenGL Render Image
3. Observe that wire is not there
4. make 3d viewport visible
5. render menu -> OpenGL Render Image
6. Observe that wire is there
This happens because If there is a 3d viewport, its settings are used, if not defaults are used.
The default that causes this is 'Nkey Panel -> Display -> Only Render'.
I would note this in wiki docs but it seems there are not even basic docs for opengl render in our wiki.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.Aug 20 2013, 12:47 PM
