particle instance modifier apply rotation even if unchecked
all
2.68a
Defining rotations parameters for the particle system is taken into account when using the particle instance modifier, even after unchecking rotation in the particle system panel.
1) open the attached file
2) uncheck "rotation" in the particle system options.
3) Nothing happens, only checking it again and manually give the default values for each parameter kind of "disable" it
We suffer severe problems with particle rotations in Blender. Sorry - but it's just crappy and nobody is able to fix it :(
You can find all of these listed here. I added your report there too, waiting for someone to work on it.
https://projects.blender.org/tracker/?func=detail&aid=32340&group_id=9&atid=498
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Aug 23 2013, 7:26 PM
ok, any plan for a rewrite ? Are Particle nodes from Lukas going to resolve the problem ?
