Vector.rotate() does not return value as documented
win 7 professional 64 bit
1.68a official release win 7 - 64bit
The docs state:
Vector
rotate(other)
Return vector by a rotation value.
it doesn't however. Keeping in line with the naming conventions I think it is indeed correct not to return a value (so a doc error, not a bug) but in that case it would be *very* convenient to have a rotated() function as well (in line with many other member functions)
>>> print(Vector((1, 0 , 0)).rotate(Euler((0, 0, 1))))
None
Note that the vector itself is correctly rotated, it just doesn't return the value. Same behaviour with a Quaternion as argument.
Good find, checked all others are documented correctly,
fixed 59318.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Aug 20 2013, 10:42 AM
