Windows XP/SP3 32bits
NVidia Geforce9500GT
version 2.68a r59448
An internal cache of Smoke modifier is not built definitely.
After having made an internal cache in Smoke modifier, I stop it with a frame on the way.
And I saved data.
I read the file and built cash from a frame on the way again.
Cash is not built definitely then.
The data of the next frame when I saved it are not right.
I want you to check because I have attached a movie.
Comment Actions
I'm sorry, but i'm not sure what the problem is exactly. The video quality is not sufficient to see what you are doing and i don't understand the description. Please try to make a test file (the one from the video should be fine) and attach it, or give detailed steps how to reproduce the problem.
Comment Actions
It did not occur when I confirmed it in the latest revision.
The problem was solved.
Thank you.
