Add Group Instance crash
Mac OSX Snow Leopard,
[more information attached in "system-info.txt"]
Crashes in current official version: v2.68.0 official, r58536
>> it does crashes in previous versions too, e.g. 2.67b
>> Commands apparently different as far back as v2.62, v2.65, so raises usage error (different)
As described in the text editor of the attached blends, certain use of the group_instanc_add operator through python instantly crashes blender or doesn't work (no error). This includes the same method the info bar claims to use when done via the UI (which does work without issues). There is at least one way to successfully run the command without crashing or exceptions, but it does not match the documentation or info log.
The attached blend just has one cube as a part of a group called "g".
The lines of code and how they behave if copied/pasted into the console are in the open text document.
Blenderartists thread:
http://www.blenderartists.org/forum/showthread.php?306855-Instant-Add-Object-from-python-cancelled&p=2465388&posted=1#post2465388
fixed 60212.
however I'd not recommend using this operator from python.
instead you can add an empty object and set its dupli-group direction.
also, the 'name' and 'group' arguments do the same thing, one is an enum and one is a string, this operator was intended to be used by the interface, where its useful to support both.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Sep 18 2013, 2:30 AM
Follow up r60213. now the info view prints correctly (without name & group both set).
