Debian Unstable AMD64, Intel Graphics
Blender 2.68.5 build from Sunday 15th Sept
Halo materials render as flat-coloured blobs if Alpha in Render Shading panel is set to “Transparent” rather than “Sky” (BI renderer).
The attached file is a simple halo-material example. As provided, it renders fine. However, go to the Render context, Shading panel, and change the Alpha setting from “Sky” to “Transparent”. Now if you render, the formerly intricately-detailed lens-flare effect is replaced by large, ugly blobs of flat colour.
Comment Actions
It's a display thing, if you set it to show color + alpha in the image editor you will see the render is correct. When you set it to color, it will show you the color of the pixels with alpha removed, which can look a bit strange but it's not wrong.
