Blender stops responding for some seconds when moving to another frame after CTRL + Z (or right after opening the .blend file)
Tested with:
--- Windows 8 x64 Pro with Media Center, NVIDIA GeForce GTX 570 ---
In versions:
--- 2.68.5 r60294, and 2.61.0 r42615 (couldn't find a version without the problem) ---
What I notice is, when I click in the strips view to navigate through the frames, something is loaded into RAM (in my project, aprox. 3 GB of RAM is taken), and then the processor does something, while Blender remains stuck.
I'm working in a not-so-complex project, where the final video is bigger than 1 one hour (30 fps), but with just 15 minutes of stripping (most of them are audio files, then there's a constant video, and small effects),
it takes more than 10 seconds each time Blender is opened, or when I try to move after a CTRL + Z.
To reproduce:
-Extract and open the attached .blend file.
-Create the folder structure for the attached file "dummy.mp3".
That is, the following path must exist:
F:\ALB3530\Music\SOUNDS\Soccer\Dummy.mp3
This is the audio file that is repeated over and over the sequencer.
-Open Blender, load the attached .blend file, and click anywhere in the strips view, in order to go to any other frame.
You'll notice there will be a delay, where Blender stops responding, and recovers after some seconds.
In the following machine:
Windows 8 x64 Pro
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16.0 GB RAM
It takes 5 seconds for Blender to respond, considering that's a very simple project.
With a bigger file and a complex project, it could take more than 20 seconds.
If you duplicate some strips, to simulate a more complex project, it will take more time for Blender to recover.
Heavy videos (and yes, full HD *is* heavy, even nowadays) take time to load. There might be room for optimization (perhaps the vse gsoc of this year addresses this), but this is not a bug! :)
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Sep 24 2013, 7:15 AM
Sorry then :)
In the attached example, I've used a simple mp3 file, that is the only file used in the sequencer, but repeated in many strips.
This file is less than 2MB.
Assuming it's one file only, I supposed the file would be loaded into RAM only once, and be used from there.
But appearently, the same file was being loaded/read from disk [the number of strips it is used in] times
That's why I thought there was some bug.... :|
