Duplicate Window crashes Blender
osx 10.8.4, macbook pro 6.2, 8GB Ram, gt330m
official 2.68a r60186, own r60385M
official 2.66 r55057 works (have no 2.67 to test)
Duplicate Window (ctrl+alt+W) crashes Blender.
I just see: This only happen if two Screens are connected, without external Screen it works.
Please do not put backtraces to the post itself, attach it as a file instead. Otherwise bug report becomes too much unreadable.
(moved backtrace to attachments by self this time).
I cannot reproduce the error here.
OSX 10.8.4, macbook pro - using an external screen connected to the laptop.
Can you clarify this? "This only happen if two Screens are connected, without external Screen it works."
By screen are you referring to displays (monitors)? Are you using two external displays? or the laptop + another one?
Using two displays, one internal, second on mini-diplay port.
Can you test if this also happens when:
* opening user preferences through shortcut
* rendering into new window
After some further tests i have to say it does not always happen:
If the window i duplicate is on the internal Display it does not crash.
If it is on external Display it crashes. It shows a new window which is blank (white) and then crashes.
It does crash on internal display if i have no external display connected though...
Here a Backtrace:
http://www.pasteall.org/45957/text
I could redo a crash with that backtrace now, fix in svn revision 60456, thanks for the report.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Oct 1 2013, 12:07 AM
