Right Click for object selection crashes Blender
Hello,
When i try to select an object (mesh, lamp, etc...) by right click, a core dump appears after a segfault.
In edit mode, this trouble dosen't appears.
Mandriva 2006, xorg-x11-server-6.9-1, ATI Rareon Mobility U1 on Compaq presario 2100 Laptop.
Logged In: YES
user_id=2923
I have the exact same laptop and works fine with Windows XP and official build (as well as my own build).
connecté
user_id=487
This is why i said "on Linux" anc "Xorg". It may be a simple bug with ATI drivers on Linux. In fact, ATI doesn't give any driver for this card to Linux. I have to use the Xorg given drivers.
The real problem is that only Blender has such of problem... and i don't know why...
This pb appears since 2.34 and the only way i have to select an object is to get it in treeview... not really cool hu ?
So, if 2.33 works, what have changed since this version ?
Logged In: YES
user_id=2923
metal3d,
I was helping to narrow down the problem - Ie confirming it was specific to the linux build, the additional information helps to assign the bug to the correct person.
Also is the Blender build you used official? If so is it the static or dynamic build? Also thanks for the additional information on which other versions do crash and also the one that doesn't.
Do you know how to build a debug build on linux? That would possibly help narrow down the problem a bit more.
connecté
user_id=487
Hello again.
I give some precisions ;)
This is for 2.40 official build and my own build has the same pb.
The bug appears only in Dynamic build.
I'm trying to do a debug build.
See ya in 1 hour ;)
connecté
user_id=487
[metal3d@portablepfe blender-2.40]$ ./blender -d
Blender V 2.40
argv[0] = ./blender
argv[1] = -d
Using Python version 2.4
Color depth r 8 g 8 b 8
Aux buffers: 0
ordered
OBCube
OBLamp
OBCamera
File .Blanguages not found
Registering scripts in Blender menus ...
Getting menu data for scripts from dir(s):
default: /home/metal3d/Download/blender-2.40/./release/scripts
user defined: /usr/lib/python2.4
BPyMenus error: too many subdirs.
User defined scripts dir does not seem valid.
BPyMenus error: couldn't write Bpymenus file: no home dir.
Aux buffers: 0
Aux buffers: 0
branches 20846 nodes 63059
raycount 0
ray coherent 0
accepted 0 rejected 0
Aux buffers: 0
ordered
OBMesh
OBCube
OBLamp
OBCamera
Erreur de segmentation (core dumped)
connecté
user_id=487
Error, i redo a compilation, this is a "release" mode compilation... sorry
Logged In: YES
user_id=2923
Hi this is a driver bug apparently... usually can be solved by changing some of your driver settings or updating to latest driver version.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:16 AM
