Mac OS X Lion 10.7.5, AMD Radeon HD 6770M 512 MB
This has always functioned properly up unitl 2.68. 2.68.5 does not function properly either, although everything is fine with Windows builds.
Changed keyboard shortcuts are not maintained upon program restart. I also noticed that there is an intermittent problem with various settings changes in the 'user preferences' panel but this sometimes happens but usually does not. I have just discovered that the 'save user settings' in the 'user preferences' pane will save the keyboard shortcut changes but I prefer to hit the save button a half a dozen times to be sure that it registers because, as I said, this button is not always working either.
n/a, it appears to be a problem with Blender not saving the modified start-up file.
NOTES: sorry for not mentioning this sooner, I did not realize that your bug-reporting would be this well streamlined.
Comment Actions
This is intentional Ctrl+U only saves startup.blend,
To save userpref.blend you have to do it from the preferences you need to do this from the preferences space.
