Fire/Smoke Modifier dont responds to mesh deforms
Windows 7 64, HD 5770
error: 2.68a r58537
Fire/Smoke Modifier dont responds to mesh deforms in:
Blender Render - Textured Display
Cycles Render - Material Display
I have attached a file.
Use the Curve or/and the Bone to deform.
Try different shading displays.
ubuntu 12.04 64bits
rev60624
I confirm that there is a problem in the .blend but I cannot reproduce from scratch.
In attached .blend, there is no update of deformation in Textured display but it works in Solid Display.
Domain's dimensions are weird. These values are equal to 0.
Youre right, the domain is kind of strange, add a new one.
I can reproduce it easily, just create a fire simulation.
1. add a cube, give it a smoke-modfiier -> set domain.
2. add a cylinder, give it a smoke-modifier -> set fire or smoke.
3. add a curve
4. parent cylinder to curve via curve deform.
Blender Render:
5. play timeline in textured and solid
Cycles Render:
5. play timeline in material and solid
Got this "bug" in all my simulations. Do you say its working for you if you create it from scratch?
4.1 Smoke modifier have to be placed under Curve modifier (or Armature mod) in the stack
OK ! I confirmed the bug with Cycles UI for Material viewport shading mode.
But I have no problem with Texture viewport shading mode.
For the moment, it is not a big problem because cycles is not yet able to render smoke.
Thank you for your investigation.
Brecht, smoke and cycles.. Do you mind looking into it? :)
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Dec 19 2013, 6:30 PM
Closed by commit rB19c0c7992a89.
Fixed now, thanks for the report.
