Modifier "Mask" not updated correctly when switching from objects
Ubuntu 12.04 - Nvidia 8600
r60988
If I apply a modifier "Mask" with mode Armature, not updated correctly when changing the focus from an object to other.
Watch video adjunct
Just for the note: sample .blend file worth 1000s of screencact videos and saves lots of time.
I'm sorry, attach a file now.
In the .blend:
Alternately selects between the bones 1 and bone 2, the modifier mask works correctly.
The error is when you select other object:
1. Select the bone 1.
2. Now select the object 2 and then select the bone 2. Alternately selects between the object 2 and bone 2. The bone 2 does not perform its mask effect.
The issue here seems to be that only the active object is marked for update when selecting a bone. This leaves other objects that depend on the armature selection state not updated updated. Attached a patch where the update is set to the armature object itself
Interesting catch, Hennik. Will check the patch a bit deeper :)
From what i could see here patch seems to be logical: arm came from selected ob, not ob_act so checking mask modifier from one object and tagging update another one seems quite strange.
But re-assigning to Joshua, maybe there's something i'm missing here.
I can't see any obvious reasons to reject this patch either. Committed as rB33bc6a3959b4f59f6ded304b5db06733653051cd
Joshua Leung (aligorith) changed the task status from Unknown Status to Resolved.Nov 25 2013, 2:21 PM
