Transformation Constraint rotation bug
win7 sp1 64bit
GT445m
Error with 2.69.1 r60982
Working with 2.49B
Rotation type with Transformation Constraint.
Rotation Error when Source-max-value big than Desitination-max-value.
Please check the attachments. (rotate the green cube)
Thanks for you hard work.
Best wishes!
Yang
Sorry. I've try again. 2.49b has the same problem. But I believe that abnormal constraint behaviour.
http://wiki.blender.org/index.php/Doc:2.6/Manual/Constraints/Transform/Transformation
This is a known limitation due to the underlying maths that we can't do much about.
Joshua Leung (aligorith) changed the task status from Unknown Status to Archived.Oct 30 2013, 12:08 PM
