Mirror Modifier in Edit Mode; only if clipping activated: when moving vertices towards their mirror image using grab: if you stop moving, as soon as the vertices meet (or move them a bit further), and then try to move them again, they won't budge.
Windows 7; AMD 760G, 1600 MB Graphics card memory
Blender 2.69, worked with 2.61
mesh, mirror modifier activated, single or multiple axis, clipping activated, in edit mode: I took a standard cube (tried it with other meshes as well) and moved it away from its pivot point in edit mode. If I now move a vertex to the point where it meets its mirror image using grab, release the vertex and try to move it away again thereafter, it remains fixed to its mirror image. It does not matter, whether merge is activated, or not.
The simple blender start screen cube will do. After having moved it away from its pivot point and using the mirror modifier on it, one or more mirroraxises activated, clipping activated as well, click on one or more of the cubes vertices. Then move them to where they meet their mirror images. You may even move them a bit further - it won't make a difference - just to make sure the clipping kicks in. Release vetices. Now try to move them away from their mirror image again. It won't work. They will stay fixed, as if glued to their mirror image. Even with the option merge deactivated. The same thing happens if you don't move them - as previously - using grab, but rather scale the model in edit mode, so the problem seems to be the clipping.
Well, this is what clipping currently intended to do: it doesn't allow vertices to cross the mirror plane and for those vertices which are on the mirror plane they keeps staying there. This is how it worked for ages and this is not a bug.
Merge is a separate setting, you might want to have clipping but not merge. In your example you might add subsurf after the mirror and see difference with merge enabled/disabled.
Thanks for the report, but it's just what the option is intended to do..
Sergey Sharybin (sergey) changed the task status from Unknown Status to Archived.Nov 7 2013, 9:19 AM
