Vertex Weight Proximity Modifier can't affect particles density (no realtime feedback)
Windows 7 64bits
GeForce GTS450
Broken: Blender 2.69 r60995 (official)
Vertex Weight Proximity Modifier (VWPM) seems to have an inconsistency behavior over Particles Vertex Groups Settings.
If I put it over the Length slot it works as expected (with realtime feedback). But the VWPM have no effect over the Density slot.
If I enable "Use Modifier Stack" inside Particles's Emission Panel, the modifier works over the Density slot, but with no realtime feedback.
After any change to VWPM, I have to disable and enable again "Use Modifier Stack" button to update particles and see the changes.
I made a test sample file:
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Nov 14 2013, 2:07 PM
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.
This is a known limitation of current particle system, which just does not support dynamic vgroups (which did not existed at time it was coded ;) )… More like a TODO item for a future particle rewrite.
