FreeBSD 9.2 amd64 Nvidia gt520
Broken: Blender 2.69
Worked: Blender 2.66
Using python I can create a group and add group input and output nodes but I can't add sockets to these nodes to connect anything to. I can create and connect other nodes within the group.
In 2.66 the following script works, it creates a group, adds a node and connects the node to the group in/out sockets.
test_group = bpy.data.node_groups.new('testGroup', 'SHADER')
test_group.inputs.new('in_to_nodes','VALUE')
test_group.outputs.new('out_result','VALUE')
node_add = test_group.nodes.new('MATH')
test_group.links.new(test_group.inputs[0], node_add.inputs[0])
test_group.links.new(node_add.outputs[0], test_group.outputs[0])From 2.67 node groups started to be edited over the top of the nodes display, this introduced group input and output nodes. This would mean the script would be changed to
test_group = bpy.data.node_groups.new('testGroup', 'ShaderNodeTree')
group_inputs = test_group.nodes.new('NodeGroupInput')
group_outputs = test_group.nodes.new('NodeGroupOutput')
node_add = test_group.nodes.new('ShaderNodeMath')
node_add.operation = 'ADD'While that much works in python I can't get a new input or output socket created to make connections.
I expect group_inputs.outputs.new() to be the way to do this but it fails without error.
group_inputs.inputs.new() does create sockets but on the wrong side showing an error - Undefined Socket Type
Manually created sockets appear to be available in test_group.inputs but test_group.inputs.new() also fails without error.
There is an operator bpy.ops.node.tree_socket_add() that will create sockets but it is only available when a node editor is in context.
