File output node only renders one frame in simple conversion setup
OS X 10.7.5 ATI Radeon HD 2600 XT 256 MB
Broken: 2.69.0 r60991, also builds hash d71bcab, 6734936
Attempting to convert multilayer .exr to png using file output node in compositor, only outputs first frame of sequence
FYI my .exr was only one layer
uploading 3 frames as example <sorry couldn't upload directly as files too large-let me know if you need .exr files to test>
-Load .exr image sequence into file input node,
-adjust file output node paths as needed
-render animation
-only one frame is output.
Let me know if you need the .blend set up with a relative path layout. Thanks.
Stephen Hamacek (hammers) raised the priority of this task from to 90.
Stephen Hamacek (hammers) updated the task description. (Show Details)
Stephen Hamacek (hammers) edited a custom field.
I'm downloading yesterday's later build to try, in case this is fixed by https://developer.blender.org/T38074
Issue still present in hash b0ab91c
I'm not actually sure what does it mean "only one frame is the output"?
From my tests exr sequence has been converted to pngs just fine. Could help if you scale exrs down and setup .blend file with relative path which fails to work for you.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Jan 17 2014, 3:45 PM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jan 29 2014, 7:46 PM
I couldn't redo this problem either but I had to change the paths, after that it outputs all frames.
I'm not sure how it could output only one frame. If it can't write to the given location, then it gives an error and animation rendering is stopped, so I guess in that case it's true that the File Output node would write one frame, then the render output tries to write and fails, and it stops.
But further, we really need more information, so far no reply in 2 weeks so will close until we get more information to investigate this.
