Windows 7{F64397}
blender 2.79
when i try to render my animation using command prompt i would tell it to start at 682 but when it starts it says it stating at frame 1365 I checked if this is the actual frame or if it just says that but it does really render at 1361. I rendered other frames to see if there is a pattern and it seems that for the most part it would render the frame that is doubled the desired number plus 1. for example if i said 455 it would go to frame 911. this error does not seem to happen with any of my other projects so i don't know if its just the blend file or something else.
i would use the basic code for rendering a file in command line (there is nothing special about it, I use it for all my projects)
when it starts where it should say Fra: 682 it says Fra:1365.
please inform me if there is something i can do to fix this because im rendering this animation and I can't complete it if it wont render at the correct frames.
