Windows 7 pro + ATI Radeon HD 5700 series
Broken: 2.69 64 bit
Worked: 2.63 32 bit
I tried to install 2.69 using both the Windows installer and the zip file. Both times the installation worked but when I tried to run blender, the command screen came up with nothing on it, disappeared and the blender screen started up but never got to the splash screen before it disappeared
questions: I uninstalled 2.63, 32 bit using the recommended process of keeping the config files and the other stuff. Are they what's causing the problem? Also I took off python 3.3x. Does that need to be installed first?
