GNU/Linux 64 bit (fedora 20) Intel CPU, Nvidia GPU
Broken: bbab2ec 2014-01-10
Limit Scale seems to use absolute values for limiting, allowing objects and bones to have negative scale values even if limit is >= 0
Create a Cube
Add a limit scale on e.g. X, lower value 0 upper value 1 (for example again)
Click 'For Transform' in the constraint just to see it quickly
Scale the Cube down on X: note it skips past 0 to negative values, all the way to negative 1
alternative just load the linked file and scale the cube.
