Computer specs.
An Intel i7 Ivy Bridge Processor, an ATI 7xxx series GPU, 16 Gigs of RAM and Win7 64 bit.
Description; The latest VC12 build from the buildbot (Jan22), shows a major new glitch in the GLSL display of UVmapped textures, as you will see in the .blend file, the UVmapping is valid and the textures shows properly in editmode, but the mapping is completely messed up in object mode.
I can confirm that this is a fairly new bug which was introduced within the last week, the bug was seen in a build done at hash c700103 while a Jan 18th build at hash 96e9c67 works as expected.
My initial suspicion is that the texture mapping was among the things broken by Bastion's commit changing the tessellation code but I could be wrong, if you can confirm and find the issue, that would be great. I have also attached an image to show that this is not due to something I did wrong myself.
