Adding two planes != separating two faces of a cube? (boolean modifier)
Archlinux
Nvidia GTX 460
Broken: 10f4c26 (2.7 RC)
Creating a boolean modifier setup with two planes boolean joined subtracting from a cylinder (see http://blender.stackexchange.com/a/7285/599 for context) does not give the same result when created different ways. Using a cube gives the expected result, while directly adding planes does not.
In the attached .blend
  • layer 1: Boolean operation set up by adding planes
  • layer 2: Boolean operation set up by adding a cube
Exact setup steps:
For planes:
  1. Add plane
  2. R+X+90
  3. G+X+1
  4. Add plane
  5. R+Y+90
  6. G+Y+1
  7. Add boolean join modifier to plane 1 with plane 2 as target
  8. Add cylinder
  9. Add boolean difference modifier to cylinder with plane 1 as target
For cube:
  1. Add cube
  2. Move cube with snapping so one edge is in the world center
  3. Delete top and bottom vertices on the edge opposite edge in the world center
  4. Select one of the remaining two faces and separate by selection
  5. Add boolean join modifier from separated face to other face
  6. Add cylinder
  7. Add boolean difference modifier to cylinder with separated face as target.
Kitt Zwovic (gandalf3) raised the priority of this task from to 90.
Kitt Zwovic (gandalf3) updated the task description. (Show Details)
Kitt Zwovic (gandalf3) edited a custom field.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Archived.Feb 24 2014, 12:51 PM
In this case face normals matter to determine what is inside or outside, since that cannot be determined automatically from a non-closed mesh.
@Brecht Van Lommel (brecht) But the shouldn't the result be the same? I don't understand how the method used to create the planes could affect it, as the objects/normals seem identical in the end (to me, anyway)..
Brecht Van Lommel (brecht) changed the task status from Archived to Unknown Status.Feb 24 2014, 2:49 PM
I closed this one too fast, will let @Sergey Sharybin (sergey) have a look.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Normal.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Feb 24 2014, 3:10 PM
Your two ways of creating the operand doesn't match really. You're adding rotation to the planes which gives a bit of float precision issues, resulting in different location of vertices in the corner which might look being at the same exact point.
Root of the issues goes to the fact that Blender uses floats and Carve uses double, which results in different epsilons being considered all over..
Doesn't consider a bug, just a specific work.
