Using tiles as ground plane
Broken: (example: 2.69.7 4b206af, see splash screen)
Using Blender 2.69 (last build waiting for the newest 2.70), when I'm using a ground plane with tiles, in "object mode > materials" the size (of tiles) is quite different that from "object mode > rendered"
santiago acebo (obkcaptain) raised the priority of this task from to 90.
santiago acebo (obkcaptain) updated the task description. (Show Details)
santiago acebo (obkcaptain) edited a custom field.
Kévin Dietrich (kevindietrich) lowered the priority of this task from 90 to 30.EditedMar 10 2014, 10:23 AM
OS, CPU, GPU ? Exact version you're using ? Cycles or BI ?
A blenfile or a screenshot would be also good.
Are you using a mapping node in cycles? currently the cycles material view in the view-port does not respect the mapping node.
Kevindietrich
I'm using an iMac 21,5" from medium 2010
OS Maverick, CPU i3 (2 cores),
I can't use GPU with this equippement.
Thanks for all
And russcript
Yes. I'm using a mapping node.
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Mar 18 2014, 8:41 AM
Well, then, as @Warren Bahler (russcript) said, this is not supported currently… not a bug, rather a known limitation.
