Blender Game egine scripting error
Windows 7 64bit, Nvidia GTX 660 Ti
2.70
If I assign a new variable (for example posY for owner.position.y) it doesn't work
cont = bge.logic.getCurrentController()
owner = cont.owner
posY = owner.position.y
posY += 0.2
If I do the same thing without the last variable everything works just fine
owner = cont.owner
owner.position.y += 0.2
Create a text file with the following code
import bge
def main():
    owner = cont.owner
main()
Add sensor Always. Activate TRUE level triggering
Add controller Python
Assign python to your text
The cube moves.
If you assign a variable to owner.position.y and set the variable += 0.2 then the cube doesn't move...
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Archived.Mar 24 2014, 2:55 PM
Dalai Felinto (dfelinto) claimed this task.
Python doesn't create a reference to the original property when you instance a float. It does if you do the whole array though:
owner = cont.owner
position = owner.position
position.y += 0.2
It's not a bug, it's how things work, closing it.
Sorry.
I didn't know.
Thanks for the reply.
