Hello
In Blender 2.70 i can not import my Key Configuration. Its working in older Blender-Versions.
Here is a Picture from the Error:
Thank you for your help.
Hello
That property do not exists anymore we can't handle that case automagically unfortunately. You have to fix the error manually by editing your keymap file and removing the line(s) generating errors.
Note that this issue has been solved since 2.69, keymap exporter now generates smarter code that simply prints a warning instead of failing in such cases.
