Blender 2.7x OSL crash
Windows 7 Ultimate 64bit
Corei7 3770
Quadro K4000
16GB RAM
Broken: 2.7a f93bc76
I start a new scene and enable Open Shading language feature, whenever I press render or switch to interactive rendering Blender crashes. I use CPU computing for rendering.
IMPORTANT NOTE: I installed Blender on other Windows 7 64bit computers which never had Blender installed and I get the same problem! OSL feature works fine on Windows XP!
  1. I start a new scene
  2. Select Cycles render
  3. In render panel I enable Open Shading Language.
  4. Press render button or switch to material swatch preview or start interactive render.
  5. Blender crashes
Einar (MonteNero) raised the priority of this task from to 90.
Einar (MonteNero) updated the task description. (Show Details)
Einar (MonteNero) added a project: BF Blender.
Einar (MonteNero) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Apr 24 2014, 7:58 AM
Which build did you try, VC2008 or new VC2013? Also, could you please try one of our nightly builds?
Hi,mont29!
I've just tried latest nightly build VS2013 for Windows7 64bit (blender-2.70-8cee587-win64-vc12.zip). Blender crashes anyway.
Regarding my older version 2.7a I don't know which VC it has. I just downloaded the package from official page.
Will check this evening on Windows. Cannot confirm any issue on Mac OS now.
Can't confirm on my Windows 7 64bit using Blender 2.70a. Using nVidia driver version 335.23.
Cannot confirm on Windows 7 x64, MSVC 2008 11310b5
Must be something special on your configuration.
Hhm. Is it possible that Blender crashes with curtain type of Windows version or service pack? Moreover I've got python 2.7 and Maya installed on the system, could they create a conflict?
Bastien Montagne (mont29) raised the priority of this task from 30 to Normal.May 4 2014, 9:09 AM
cant enable OSL at all when in render view or rendering. tried multiple builds. x64 builds all crashed immediately even with no materials. the official win32 build is fine until a material node is connected with a material output. then it crashes.
<!> event has invalid window
this is all that showed up in console. it also seems to throw errors if you accidentally connect say a shader node to the fac input of a ramp. did that on accident because of messy organization of nodes. it crashed it like connecting a shader node to output with this.
Cycles shader graph connect: can only connect closure to closure (bsdf.BSDF to r
gb_ramp.Fac).
w7 x64, also have maya installed and the remnants of c4d.
of course that's a dumb thing to do and it wasnt intentional but that shouldn't crash blender.
edit: ps cant use osl with anything after 2.66. the default cube takes longer to crash. just guessing it seems to be something with updating the material preview.
being in anything other than the materials menu when connecting the node reliably gives some extra time before crashing. less complex materials reliably give a few seconds more before a crash. moderately complex geometry and more complex materials crash almost instantly.
anyone else want to try to replicate any of this? is it just on this end or are other people getting the same?
woops is this double posting on edit? it looks like it.
Can't repro on Win7/64 with any blend file. (Also not inside VM on WinXP/32.)
Tested to see if it was OS configuration or specific to a service pack or update. It doesn't seem to be service pack specific, a bare bones install of 6.1 sp1 did nothing for it. However a complete install of 6.1SP1 and all of its associated updates resulted in a working OSL option.
Would MonteNero be willing to try to update to SP1 or SP2 to confirm? Or if already on SP1 try going through one of the windows 6.1 updates to see if one fixes the problem.
