Win 7 and Ubuntu 13.4
Broken: 2.7 f93bc76
Worked: 2.69
using cycles
If I keyframe the "enable/disable render layer" toggle, It will work correctly during timeline playback. But if I render an animation sequence, the keyframed toggle will not evaluate.
- Open the attached file. Scrub the timeline and note that the render layer "monkey" is keyframed to turn on on frame 3.
- Press CTRL F12 to render animation, note that the keyframe does not evaluate and blender only renders the "Cube" layer.
Also,during rendering, if you switch to another properties editor tab, and then back to the renderlayers after frame three, you will see that the tick box refreshes correctly, but still does not actively render.
